Goodman, although on the lower part of the cost scale (plus or minus 1200 bucks for the model you mentioned), isn't a terrible choice of brands. Runs 14-16 SEER, which 13-26 is the typical scale for "efficient" HVAC condensers. So it's closer to the bottom of that scale. Not that it's a bad thing. To get higher SEER, means more $$ upfront, so in reality, what will you pay for overall? If electricity rates skyrocket, maybe think higher SEER ratings? I wouldn't go just by that, however. Overall reliability is the key here, I think.
They run copper tubing so that's good, too. They're generally pretty reliable units. I want to say they have a very good warranty on the compressors, although I haven't seen any specifics on that lately. It was like 2 years replacement, and 10 year major component warranty. Not sure if they still offer that.
We still have the same old 2.5 ton Goodman that was installed when the house was built in 2004. Albeit the compressor was replaced under warranty in 2007, haven't had an issue other than an evaporator change out (under "special" warranty- again, bad design), a condenser fan motor, a GE start capacitor and one heater element switch (bad design, new design got installed) over the 17 years. So other than filters, I've spent about $300 in maintenance costs and doing all but the warranty work myself. I've been meaning to get around to replacing the unit with a more efficient unit, but haven't felt the need to. It ain't flashy, but it works.
When it came to A/C units, it used to make a difference on which brand and price range you considered. Not so much anymore. Sure, Trane and Carrier are some of your "top" brands and you pay accordingly, but they ain't what they used to be. They all seem to have their plus and minuses.
