I need a little help from all the stock 442 guys plzz
84cutspreme
1,163
158
Okay first off this is not for my car its a buddy of mine, he has a stock 85' 442.
He needs to replace a few things and is having a few small issues, maybe you guys have run into before:
I would like to know what parts you guys would use to replace these and some part #'s if possible,
Rear Shocks
Radiator
Intake Manifold Gasket
The problem he is having only happens when he starts up the motor. He says there is a strong smell of fuel right after starting it up. After a few minutes it goes away. I figured that was choke acting up.
GM 3043077 radiator is discontinued but replacements are available, you can actually still find a GM radiator but it's pretty expensive, GM has an alternative listed that's about $275.
Intake gasket is available.
Air shocks are discontinued, best to find aftermarkets
www.rockauto.com is his best bet.
Rear Shocks
Radiator
Radiator....CU162 at AZ...lifetime warranty
Shocks 69604 at AZ with lifetime warranty
Intake gasket at AZ MS96039 1yr warranty
