i need an alt bracket for an olds 455!
depending on what kind you need.I have a set from a 350,will fit a 455 though.These brackets are for cars with a/c,so they go on the driver side of the engine
yea mine is on the passenger side. i just kinda have it rigged now but really want to get the proper bracket.
You can use a bracket off of just about any Olds engine. At least the upper bracket. The lower bracket is longer than a SBO bracket due to the deck height differences.
On mine I'm using a 307 aluminum upper mount with the 455 lower mount.
Which mount are you looking for? Top, bottom or both?
I have a top mount from my 455 that was in the '76 Custom Cruiser. But it places the alternator out kind of wide and you can only run a stock height valve cover. Also not sure if it would work with the pullies you have.
Yea I need both of them. The bottom one I have is just a metal spacer and some washers to get it pushed out enough. The top one is a universal type bracket I picked up at autozone. But it's still off and I'm afraid I'm gonna throw the belt. I have stock height valve covers now. But I know if I go to rollers then I'll have to change right?
