advantages--mutiple sparks to about 3000 rpm (varies from model)
worth the money--depends on your application and performance
yes you don't need a computer
main purpose--to provide you with more efficent fuel burning
pointless unless you have a high compression ratio, (higher octane fuels require more spark to ignite) it will privide a power spark
so if you have a moderate engine combo, i would just upgrade my stock unit or buy a high performance distributor it will work fine. if you got the upgrade route component matching will be you best option ei. an accel mondule will not perform the same on a msd coil and so on, so buy the coil that matches the module
