Just so no one else gets burned, there is an eBay seller out of Los Angeles (Norwalk, CA) misrepresenting some other form of inner bucket seat belts as being original and correct for G-bodies:
http://www.ebay.com/itm/82-83-84-85-86- ... true&rt=nc
They are shorter and do not mount in the car correctly, they can be used and will still function but are shorter and mount in the car differently as pictured below.
I recently found this out trying to sell a pair which I happened to purchase many years ago and did not realize until I was "harassed" about no G-body's coming with black interiors in 86-88 which I was under the assumption that Montes did...
L.A.X-RATED seems to know allot about what cars they are from, I suspect the ones pictured could possibly be from a different vehicle as described below since they do not look trimmed, who knows.
Regardless this post is to warn others so as they are not deceived by sellers out there... here are the photos, you be the judge:
L.A.X-RATED said:well i was waiting for someone to chime in with the RIGHT answerbut since no one has it,i will tell you these are not even from a "gbody"
(ONLY 78-81 gbodys offered black as a seat belt cover,and m not 100 on if they even made "black bucket seat reciever "sheathing") i get them are from 87-91 cutlass calais,ninety eights,chevy cavaliers,and lumina's.they fit the 86-88 gbody "male" buckles/connects. ive removed sheathing and "trimmed down"these (topside,as the older 78-85 "metal raw finnished recievers ,are too wide)DAMNIT kevin(od showtime) must be busy,as he is the only knowledgeble individual that i know on this 'interchangebility factor"
