interior courtesy lights
86RegalGrove
10
I have a 85 Regal interior courtesy lights don't work. I changed the the fuse but it blows it every time. I don't think there is a short anywhere as this car has everything original. Please help!!
if the fuse is blowing that means that somewhere the the circuit is pulling to much power...if your really right and there are no shorts than a bigger fuse will help
if your wrong and you jam a bigger fuse in to fix it, you risk burning something up (generally what ever was causing the problems to begin with)
Thanks, I figured out what the problem was. The cigarette lighter was just sparking when I put a bigger fuse so I just disconnected it I guess I need a new one. Know I'm trying to figure something else out the power door locks don't work and I can't seem to figure out where the fuse for that is @....
