I'm looking for help to remove a partially loose piece of trim - located above the back window, 86 Monte Carlo. At the rear corner where it meets the plastic side panel it does not fit flat and is dented. The plan is to re and re the piece(I'm sure it's metal) remove the denting and touch up the paint. I have tried to remove it using the same technique as the trim at the top of the door frame.
If someone could point me to the trick or tool it would be appreciated. If a special tool is needed I could probably make one if shown a picture.
It looks like there had been a back window leak and someone tried to seal it from the inside, I guess.
Thanks
Ed
Thanks
Ed
