interior pieces
amplified
n00b
Oct 16, 2009
Hey whats up fellas? Can you tell me if the interior for a 1979 monte would fit a 1986 cutlass?we are talkin let me know if you know if the dash ,seats ,door panels, will all fit thanks
The dash will fit but make sure you get the ducting behind the dash. I've heard some dashes have the vents in slightly differant locations and the ducting may be shorter or longer.
The upper rear side panel that goes around the side rear window will not fit as the side windows are differant shapes. The lower rear side panel will fit as well as the rest of the interior. You may have some small issues such as the Monte door panels may be window cranks and the Cutlass is probably electric windows. I've also heard that the full 1 pc front bench seat uses only 4 floor mounting points (2 on each side) where the split bench and buckets all use 8 mounting points.
