Interior trim
Deadeyejedi80
133
144
61
Saratoga springs ny
Can anyone confirm or deny if the interior b- pillar trim fit all cutlass monte and Buick from 1978 to 1988? Thanks
I always thought they did.
GM parts books says...…….
RH is 20548764, LH is 20548765 for 81-88 G47 Olds.
RH is 20062222, LH is 20062223 for 78-80 A47 Olds.
I would say based on part numbers, that no. They are different parts.
They are different, but will work in a pinch. Usually makes a a "wave" where it abuts the lower quarter trim panel/pillar trim
Thank for the help I’ll keep an eye out for the 78- 80 for now .
There's probably a little nook or cranny or flange size or something just a bit different. Can't see them being wholesale different.
Oh, just saw the post from Ribbedroof that says they would work in a pinch. But I agree, unless you had to, try and find the right year range.
I believe the difference is in the angle of the B pillar above the beltline. This would be the same area where door glass differs among the coupe body styles.
My former Malibu was using 85 Cutlass B pillar trim, it was all I could find that wasn't dry-rotted to chalk.
Reactions: fleming442
