Hello,
I recently bought an 86 442 with 95K on it. I noticed the car sits a little lower on the passenger side. I let all the air out completely out of the rear shocks and took measurements. The driver side front sits about 3/4 inch higher than the passenger side. The driver side rear sits about 1 inch higher. This was even after swapping both rear springs around. (the measurements stayed consistent before and after the spring swap) The body lines are all very straight and I cannot see any visible frame repair on the car The car is very solid, hence no rust where the spring pockets are. Is this common for these cars or should I maybe take it to a body shop to see if everything is properly aligned? Thanks!
