Kicker Panel Removal?
85CutlassSalonRyder
122
37
Dallas,Texas
How do I remove the kicker panels without breaking those little plastic pieces at the bottom? I think the lil pieces are "pop-out" I believe but I just dont want to break them in the process. Any Info will be Highly appreciated!
I remove the sill plate first...then unscrew the screw that hold the dash end to the door jamb at the front. From there I usually just grab the panel at the bottom where it starts to angle up and just kinda pull it into the car. The drivers side you'll need to finese around the hood release but it's not too bad. There's a plastic clip attacthed to the back of the panel that push into the metal behind the kick panel so it might seem like it won't come off but it will.
Hope this made some sense.
Well unfortunatley GM thought it was convient to put a ****ing computer behind the passenger side kick panel. I had no idea it was there and most of all, i didnt have the time or apparatus for the job. Thought it was going to ba a little simpler than that :evil:
