Lq9 swap in a 1979 Monte carlo
2
41
Doing a ls swap in a 79 Monte. The engine is a 6.0 liter vortec out of an 01 Denali. I'm changing the heads and going with an ls3 intake. I'm using a 4l60e trans. I want to use all of my truck accessories if I can. Was wondering what engine mounts and transmission mounts I should go with?
Thanks for the help. b*tches
Don't take the lack of response personally. This topic has been covered numerous times, both here and on a number of other sites. A bit of reasearch should show a wealth of information in this regard.
If you go to ls1tech.com, then go into the section called "conversions and hybrids", there are a number of G body LS conversion threads. Probably the best one for you though, would be the thread on the new Hooker/Holley G body conversion mounts and headers. The info in that thread should answer most of your questions.
Good luck.
