the setup I have is a Cammed lq4, with ported 243 heads, fitech tall manifold, fitech fuel rails and 55# injectors, it’s going to Be ran N/A for now shooting for around 400-450 hp.
20 gallon fuel cell, -6 feed to a 255lph pump, into the c5 filter/regulator, returned into the tank also through -6, I’m going to install a breather/check valve on the other unused return port of the cell.
My question is, when feeding the fuel rails, would it be advantageous to have a Y split fed into each rail, and a crossover at the opposite end, assuming this is the parallel way, which I’ve heard to possibly have issues of vapor lock
Or just feed into the back end of one side, through the rail, out through the crossover to the other rail, and than cap/deadhead the back of that rail in series?
Thanks!
Thanks!
