Hi all,
Looking for opinions on what to do with my 86 Monte Carlo SS. It currently has a 95 LT1 with a 4L60E. I'm not happy with the lack of diagnostic and tuning capability with the current computer and the inherent opti-spark problems (been stranded on the side off the road in two different cars because of dead opti's), I've pretty much stopped driving it because of ignition knock under acceleration. I have a low mileage 350 cloned to ZZ430 specs with a TPI induction and the original TH200-4R from the SS sitting in the garage. I am planning to convert to an LS based computer setup with whichever way I go, but can't decide what engine and trans combo to go with. I can update the current engine harness to add the coils and crank signals using an LS computer. Here's the 3 options I'm considering:
1. Keep the current LT1/4L60E and just update the electronics using a torqhead signal kit.
Pros: Shortest down time, don't have to redo the A/C, P/S, fuel lines or cruise control setup.
Cons: Cam and crank signal kit costs about 2X what the GEN 1 parts would run, ugly accessory drive all mounted on passenger side, servicing the P/S pump and A/C compressor is a huge pain,
very few options and fairly expensive to change the accessories
2. Use the TPI engine with the 4L60E
Pros: Lowest cost, should be worth over 400/LB & HP with the right tuning
Cons: longer downtime, would have to redo A/C, P/S, and fuel feed.
3. Swap in the TPI and TH200-4R
Pros: similar to option 2
Cons: same as option 2 plus highest overall cost since the trans would need to be rebuilt, would need to figure out a VSS signal for the ECM and cruise control.
Let me what you think and if I've missed any pros or cons.
TIA,
Craig
TIA,
Craig
