has anyone swap an lt1 are ls1 in there cutlass and is it a hard thing to do and get done and what wud i need to do thinking bout doing this in my cutlass since i messed up my 350 rocket engine thanks
I AM IN THE PROCESS OF PUTTING AN LS3 IN MY 1988 MONTE SS RIGHT NOW. I WENT WITH THE GM PERFORMANCE PARTS CARBED LS376. THIS A VERY EXPENSIVE PROJECT. FAR MORE THAN I HAD ORIGINALLY THOUGHT. THERE WAS ALOT OF THINGS I OVERLOOKED IN THE PLANNING STAGES. SOME THINGS TO BE CONSIDERED. YOU WILL HAVE TO GET NEW MOTOR MOUNTS. THE CONVERSION MOUNTS MOVE THE LS FOWARD AND UP A LITTLE BIT SO THE ENGINE WILL CLEAR THE HEATER HOUSING. I ELECTED TO KEEP AC AND HEATER. I'M FUNNY LIKE THAT. I PREFER TO CRUISE IN COMFORT. YOU WILL NEED A DIFFERENT CROSS MEMBER AND DRIVE SHAFT OR MODIFICATION TO BOTH. YOU WILL NEED A SERPENTINE ACCESSORY DRIVE. I BOUGHT A HIGH MOUNT AC BRACKET TO MOVE MY COMPRESSOR UP TOP TO AVOID FRAME CLEARANCE ISSUES. YOU WILL HAVE TO CONVERT TO ELECTRIC FANS. YOU NEED AN ELECTRIC FUEL PUMP AND PRESSURE REGULATOR. IF YOU ARE GOING TO RUN YOUR FACTORY GAUGES YOU WILL NEED TO GET ADAPTERS TO GO FROM PIPE THREAD TO METRIC STRAIGHT THREAD. I HAVE SPENT A SMALL FORTUNE ON MISC CRAP TO GET THIS THING DONE. FINDING RADIATOR HOSES THAT WOULD FIT WAS A MAJOR PITA. UNLESS YOU ARE GOING TO USE THE COMPUTER AND WIRE HARNESS FROM YOUR DONNER CAR YOU WILL NEED AN ENGINE CONTROLLER AND FAN CONTROLLER. THE LIST GOES ON AND ON. ADD ON A NEW 12 BOLT, REAR DISC CONVERSION, HUGE FRONT BRAKES, AND A CALIFORNIA PERFORMANCE TRANS 200 4R AND STALL CONVERTOR YOU HAVE THE PRICE OF A LOW MILEAGE 2008 Z06. THANK GOD THE MONTE DOESN'T NEED ANY BODYWORK OR PAINT. IF YOU HAVE ANY QUESTIONS SEND ME A PM. I WILL TRY TO HELP YOU OUT.dwoot415 said:has anyone swap an lt1 are ls1 in there cutlass and is it a hard thing to do and get done and what wud i need to do thinking bout doing this in my cutlass since i messed up my 350 rocket engine thanks
