"Make it yourself" or an "Improvise" section......
I like stuffing big tires under any car. I wanted to run bigger tires but I couldn't get them in the rear wheel well.
I disconnected the shocks and almost got it to fit. So.... I made a trip to Home Depot and bought 2 threaded sleeves (1/2" course thread) and I put a piece of threaded rod between them. Then I welded a 2" piece of angle iron on both ends, horizontally.
I put this homemade "Gadget" between the rear end housing and the frame, then wound it out with two wrenches (About 2")... it worked and I was able to install the tire.
Flat tire on the road, no problem because w/o any air in the tire it will come out of the wheel well easily. And, no problem installing the space saver spare until you get the tire fixed or replaced.
I needed a bushing for the brake pedal pivot on my old Ford. I couldn't locate one, so I took a ride to Home Depot (Again) and walked around til' I ended up in the plumbing dept. I took my tape measure out and measured every pipe, elbow & fitting they had. Luckily, I found that a kitchen sink (Chrome) drain pipe had the correct inner & Outer dimensions. I cut it to length in my vise and banged it in place. It was better than new, no play in the pedal and it only cost me $1.59 plus tax!
