HELP Malibu ls2 swap and paint code help?
malibu80Relli
5
West Seattle Wa
So I just bought a 1980 Malibu landau coupe with the two tone factory paint, it was a parts car. With that being said the car needs a couple things. First, I have a LS LQ4 thats going to go in the Malibu. Second, The original owner only bought it for the trim interior/exterior parts. It has factory the factory buckets and center console floor shifter. Still has the factory th350 and 268ci sbc. I located interior/exterior parts already. Need the interior color code so I can repaint and match. This is going to be the base of my build.
Dumping the small block and going LS
info needed
ls2 swap part list (going carb)?
*wat headers will clear?
*motor mounts that work best?
*do I need a wiring harness if I use msd box?
*two tone paint codes and interior color codes
*cluster swap info for 6 gauges
*ect....
mikester
2,921
3,687
Small town NY
First thing you should do is pop the hood and look at the cowl tag on the left side. Thats going to have the number codes for the paint and interior. Post the numbers or take a good close up and post it on here and I can give you the info you need.
