How does the undercarriage look underneath your car. If it is heavily rusted, depending on what part of the country your in, then you might want to replace them. I got away with just disconnecting them and blowing them out with an air gun. They should work just fine with the LT1 motor. Do you have an electric fuel pump for it as well?
Another really important thing you need to know deals with that return line that runs on top of the frame on the drivers side of the engine bay. It is normally hooked up to the charcoal canister. This can be utilized as a return fuel line to your gas tank. THE PROBLEM is that towards the back of the gas tank at the top of the sending unit (I forget where exactly) there is a brass reducer in the line that WILL cause your gas line to rupture and is well known for causing car fires. I did a holley projection kit on my engine once and luckily another buddy of mine informed me of this brass fitting before it was too late (thank god). Overall I hated the kit and went back to simple carbs. But I'm not sure if the LT motors utilize a return line or not.
