mild 406
I think you'll find alot of different ideas on what everybody considers "mild". I would consider mine mild, or streetable.
406, 509 casting (the good one) .030 over
9.9 to 1 comp
6" rods
Internally balanced
Edelbrock RPM heads
Lunati Hyd roller 226/234 .530/.530 108
Builder says 415hp+ 500 ftlbs
to me, mild is powerful but fully streetable ie 87 octane, low end torque, limited warmup, etc
i'd get bowtie vortec heads with 185cc runners and larger valves. d-dished pistons with 10.5:1 static compression, 230-240lift cam (@50) rpm intake, and either EFI, in which case i'd increase the compression to 11:1, or a q-jet. my 383 is extremely streetable with a similar, but smaller, build. i figure you'd get at least 450hp.
^230-240 duration @.050*
Thanks for the correction! Yeah, 230-240 duration and .500 lift
