MINI SPOOL?
1985Chevycutlass
Feb 4, 2009
78
Someone told me to get a mini spool since I dont have positraction, WHAT THE HELL IS A MINI SPOOL?
You dont want a mini spool if it is a street car. They are pretty much only used for racing and off road driving. It keeps both rear tires locked and it makes a car harder to turn and strains the axles. It will probably wear out tires faster also.
If the car is driven on the street, a limited slip diff is what you want.
oh ok thanx 4 the info.
I would agree that a tight posi is all you need for a street car.
If, however, you want/need a spool I believe the Detroit Locker would work.
It is locked like a spool most of the time but springs inside allow it to "click" and unlock when you need the wheels to rotate independently.
http://www.eaton.com/EatonCom/ProductsS ... /index.htm
Again, stick with a posi and you will be just fine.
Jegs
does Jegs sell posi units, if so can someone put up a link.
😱 HELL YEA GOOD LINK. It says its for vehicles with 3.08 and down. I got 3.42. Will it still work?
