More In progress shots
6,687
34
Tampa Bay Area
Well, these shots show just how involved this project has become! The car is gutted and is being de-rusted to the best of my abilities.
Here's the car as it basically sits today-except it is now up on ramps for floor repairs
Rust on underside of roof. I used Eastwood's Corroless on it last time....Guess it doesn't work well. I ground it all off and etched it with acid before treating it to cold galvanizing primer this time. It has zinc in it and should do a better job, but will be covered with Rustoleum too. No matter what you do to protect your car, if it is exposed to the elements outside it will rust. Mine sat outside for a few years as an abandoned project and rusted everywhere inside! I had even drilled drainage holes in the rear floors and had no interior in it, but the rust still killed the floor underneath the support braces. I haven't had the windows sealed to the body in so many years I can't remember, so I am now paying the price for my neglect.
Here's the right rear corner of the car. You can see that I ran the wiring for the RCA cables and front speakers in the factory positions. I eliminated the GM wiring and ran it all behind the dash with the dash out, running it on the HVAC box where GM ran it's wires when the car was new.
My infamous JB Weld rust repair. I removed every spec of rust and cleaned the pits down to shiny metal. Then this side I sprayed with etching primer followed by the JB weld. I also peeled up the edges of the seam and removed all of the rust there as well. Then I put the JB weld in the seam and smashed the seam flat with a hammer and dolly. The bottom seam was also stripped and sealed in a similar way, then everything was painted with the galvanizing primer to seal out any moisture.
The one roof patch I had to do this time around. I am not a good welder, so I had to spend a bit of time with the flapper disc on the angle grinder!
My messy trunk, full of cardboard for mixing filler, spare parts and some tools. I have great plans for this space in the future though...
Thats a lot of work, it'll be worth it when its done! You could say your Cutlass has a lot of "junk in the trunk" :lol:
...and in the garage, the spare bedroom, master bedroom, kitchen, laundry room, living room, dining room, porch,....
I'll also add some of what the car has. It has the 355 Chevy in my sig, but I also have a posi I will install shortly, 970 watts worth of Alpine amps and a CD player that is not in the car, The paint will be Diamont base/clear in the same GM Navy Blue Metallic the car is now, a mint condition dark blue Brougham interior ( wish it were buckets...), new carpet, all new weatherstripping ( in bags), Global West upper arms for the planned tall spindle/12in brake swap, FE-2 suspension sway bars, etc. I also have added some options the car came without including: power locks, gauge package, remote trunk release, intermittent wipers, tilt wheel, and am adding cruise control as soon as I find a complete setup off a Chevy powered G body from 1985. I am also planning on using factory oil and transmission coolers off a 9C1 Caprice. Another thing I am doing is adding Dynamat ( or generic equivalent) to all of the interior and trunk surfaces and then adding Jute sound deadener on top of that. I may also use structural foam in the pillars and around the edges of the roof to further stiffen the body and give it a much more solid feeling.
