moroso trick springs possible problem?
mebe007
1,808
4
36
newport news, viginia
ok so i put in my rear trick springs today and my summit 3 way adjustable drag shocks. my problem is that the front still sits like 1.5'' or so lower than the front. are these springs supposed to lower the car? what is a remedy to fix this? spring spacers?, or switch the front springs to trick springs also? please help im lost here
I am assuming you mean the rear still sits lower than the front?
what I did to get my front up is ordered front springs from 68 chevelle station wagon with a big block (30 bucks if I recall right). I have about 1 inch of upward travel till I top out the upper control arm. but then again I dont care about bottoming the upper control arm I needed the heavier spring to catch the car when the front end comes back down..
yes the rear sits lower than the front, given i still have to put the hood and driver fender back on but it should make that much of a difference. i have 1 air bag now i could put in but i would still need another for the other rear spring. i could take some sh*t outa the trunk too maybe thatd help, just boxes in there though?.
