Moroso Trick springs vs V-6 non a/c springs
JBreu
2,167
20
38
54
Livonia, New York
I will be doing some suspensiopn mods here pretty soon to include lakewood drag shocks 90/10 up front and 50/50 in the rear. I was also thinking about going with the moroso trick springs on all 4 corners as well.. I was told that I would be better off going with non a/c V-6 springs for the front ....I have the sbc with aluminum heads. What are you guys using for better traction and weight transfer???
I been running the v6 springs up front with koni drag shocks and moroso trick spring in the rear with a single drag bag and koni drag shocks as well. Car dead hooks and weight transfers very well. Has been a 1.52 60 ft.
Im running front v-6 springs now because my trick springs up front died. im going to be switching them over to trick springs in a few weeks.
Im running 14" 130# springs in the back with a ARB, going to mess with that alittle bit soon.
I still got the rear trick springs if you want them. Ill sell them cheap.
GhettoRacingKid, You have a PM on the rear tricks 8)
