Short background:
I recently went to a chassis dyno to help me set my carburetor as I was having problems with it being rich. According to their sensors, the fuel mixture seems to be pretty good and I have great throttle response. During the procedure, one of the guys who worked there recommended that I replace my Distributor cap on my MSD 8555 as the springs that hold the cap down were extremely worn. What I had looked like the “2 piece” ford style cap. The guys at the dyno shop recommended I replace it with the MSD 8433 & MSD 8467, which I did. Now the motor is VERY sluggish when I push on the throttle and pops and snaps (especially @ low RPM). It also tends to backfire if I “snap” the throttle too quickly. Not a great trade from my old cap. I have managed to adjust the timing a bit to help, but it is nowhere near drivable yet. I have purchased the MSD 8464 kit and had a couple of questions
Right now the springs are both the light silver and the bushing is the black one. The engine is at 14 initial & 37 total. When we have the timing light on it, the total timing is VERY erratic. Any thoughts on how to settle it down a bit? I heard this could be due to the digital gun? Any truth?
Here are my motor stats:
383 Stroker
Chet Herbert cam (.499-.502, 223deg – 234deg @ .050, 108 L.S.)
Victor Jr intake
Holley 750 DP
10.5:1 compression
92-octane fuel.
Max torque was reached at around 4000 RPM according to the dyno
Max rpm 6200
1979 Monte Carlo
95% street & 5% track driven
MSD 6AL, Blaster 2 & 8555 dist
Dart Sportsman heads 200cc, 64cc chambers, 2.02-1.50
2400 RPM stall
The motor runs about 190F temp.
Idle is 700 - 750 RPM
The motor doesn’t carry a large amount of vacuum
The MSD box is wired directly to the battery
At 14deg initial, my mini starter doesn’t seem to have any trouble turning the engine over & I don’t have any engine kickback. However, I have dieseling (run-on) when I try to turn the engine off and some sluggish throttle response as well as backfiring when I step hard on the throttle. I haven’t driven it since I changed the cap to see if I get a pinging under load, as the thing just isn’t even close. (I also just replaced the alternator the same time I installed the new cap as the alt was weak.)
What spring/bushing should I run (or at least start with)? What should I set my initial/advance timing to as a starting point?
HELP!
Thanks,
Russ
383 Stroker
Victor Jr intake
Holley 750 DP
10.5:1 compression
92-octane fuel.
Max rpm 6200
1979 Monte Carlo
2400 RPM stall
HELP!
Thanks,
Russ
