Ok, so as mentioned in these threads: http://gbodyforum.com/viewtopic.php?f=3&t=46741#.Ukivbj9JHIg and http://gbodyforum.com/viewtopic.php?f=10&t=47725#.UkivQD9JHIg, my car pings despite the 7.5:1 compression that the 260 V8 has. By the way, the diagrams at Autozone that one of those threads links to - well, my car is fig 25 - the more complicated one. Of course.
Previously, it seemed like it got a little less sensitive, and would ping a little less than before. However, in the past few days, it's gotten REALLY touchy - even the lightest throttle may cause some pinging once fully warmed up, and heavier throttle will rattle unsettlingly.
Well, finally got the time to start playing around with it, and discovered a few things:
- Minor oil leak around the valve cover in the #8 cylider area... of COURSE the hardest to reach area...
- Some blow by - if I get the engine at 2000 RPM or so, I can see vapor coming from the crankcase tube (that goes from the driver's valve cover to the air cleaner assembly)
- My timing is only at 18 deg BTDC,
- At idle, vacuum is only around 16 or 17 mm Hg
Found most of this while trying to track down the reason for the pinging. Well, the timing isn't too advanced, as it's actually 2 degrees retarded from spec, and vacuum is being supplied to the EGR valve... though I don't know how MUCH should be supplied at any given time. It obviously varies given the amount of throttle opening, and doesn't get any when the throttle is at idle.
When things finally warmed up, I figured I'd see if the EGR valve was actually working... could've sworn I'd checked that before and it did. Now, however, using a vacuum pump . . . nothing. The EGR valve will not hold any vacuum at all.
Ok, so I guess there's my problem. I suppose it was intact when I was barely using the car, then regular use caused it to finally give up the ghost.
But HOLY CRAP . . really? These things are over $50 new???
