my 79 el camino project
nowwhutt
n00b
Sep 5, 2014
32
here some pic of it all gutted.had a lot of rust around the front window and setting up to cut out all the bad and fill it in.had to find a g body so i could cut the bottom window out and fix the rust on that ill post more pic after i cut it out and wen i weld it all back
hay sorry it been so time since i posted something but im still working on it found so stuff for it and trying to do a lil body work i can to try to stop all the rust.but i need to take some more pic tomorrow still looking for more parts and tips lol but the big dream is to swap to a 454 and to swap to a turbo 400 transmission got the whole power train need a rear end thinking of run 370s? in the back.so i been make a lot room for the big block.took out the a/c box.but needs more work rust... o and i found this old a/c face plate in it idk? wat it is i haven't been able to find one.so im always open to comments.
That's a radio delete plate.
If you want a radio finding a plate should be easy.
Sell that one if you don't want it, don't try to cut it to fit a radio.
up date! been busy with work... i got more done..hope my welds don't look bad.hope to hear some feed back.
