Could someone please post pics showing where they notched the frame on a g-Body car for the A/C compressor lines & for the stock LS1 oil pan to clear. Thanks!
It all depends on what mounts you are using. I think the setback ones you will need to notch quite a bit off the frame. The BRP ones supposedly will fit with the stock F-body compressor.Veltboy618 said:Could someone please post pics showing where they notched the frame on a g-Body car for the A/C compressor lines & for the stock LS1 oil pan to clear. Thanks!
85GPLef41 said:I am thinking of going with the CTS-V oil pan for my LS swap.. As for a/c i am not running it for now.. I think i read somewhere that if you used the the 1in setback plates that would provide clearance for the stock f body oil pan, and power steering and a/c but i would require heater box clearancing.Not to mention the header fitments.... Who is running the BRP kit?
LS1GN said:BRP = cha ching!
I used the stock truck pan (already on motor) and the trans-Dapt motor mounts designed for an LS1 into a Chevy S10
I used the pacesetter headers and the stock truck accessories - my cost was $69 + $252 or $321 total
85GPLef41 said:What trans/ trans crossmember you using?
