Need help 88 cutlass
RON
n00b
May 29, 2009
2
I just rebuilt a 307 olds but now my power steering pump pully dont line up to the pullys on my moter and my belt keeps spining around.Does any one know how to fix this problem
Is this the same motor that the pump came off of? If so, you forgot the spacers between the pump bracket and the block. One goes on the stud at the bottom of the front cover and one goes between the bottom of the bracket and the side of the block in front of the motor mount.
I hade the same problem with this moter i broke my belt and blew my head gasket it is the same pump it wasent lined up in the first place i have the spacers where you say just cant get power steering lined up 😢
Well, it was lined up when it left the factory, so the only options are 1) the spacers are wrong, 2) the brackets are installed incorrectly, 3) the PS pump pulley isn't pressed all the way on the pump shaft, or 4) you don't have the correct pulleys.
