Need help asap
Dripz1985
31
Just came back from the rim shop. I orders 18x9.5 boss 338 rear rims with 275/35/18 tire will these rub???
Rim info: backspace is 5.031 and offset is -4.00mm
I'm not to good with figuring stuff like that out but I'm running the same style rim 18x8 with 255/40/18 tires with 4.5 bs and 2mm offset. You can see a picture under the before and after 2" drop thread
Can someone give the exact part number from summit on some rear struts and shocks.
have the same wheels, drivers side rubbed but solved it by installing a spacer and longer wheel studs. I did put new studs on all for corners but the drivers rear had to be a bit longer due to the spacer.. ordered from GM performance parts.. can get you part numbers later... gbody rearend have no struts... Hotchkis coils and edelbrock shocks on my ride..
