Car is an 85 Pontaic Grand Prix. Originally had a 305 Chevy in it (came stock). I switched it out for a mid 70s 350, at which time I used the flexplate off the original 305. Got some headers and realized they weren't going to fit (nicely) without a mini-starter. Except..the mini starter I have won't fit. See pics:
Mini starter:
Stock (mounted on the original engine..no reason):
If you can see from the pics, the tip of the gear that pops out, on the stock starter, is vertically flush with the block (meaning if you held a ruler or straight edge up against the block, it would touch the block and just touch the very tip of the gear that pops out). The tip on the mini-starter is not, it hangs out about 3/4 of an inch. When I went to install the mini-starter, the gear was already bumping into/touching the flexplate and it wasn't going to work. It doesn't need to be shimmed down, needs to be moved towards the front of the car (if that makes sense..but it's too much distance to move to make a bracket or something myself). Now the mini-starter I got off craigslist for $20, but I really want to just buy a new one, which should I buy? Has anyone run into this before? TIA! -pontiacfan18
Mini starter:
