So I have a rather peculiar set- up. I think you guys shouldbe able to help me figure some things out though. Nothing too wierd, I just haven't found any really good info on what I need.
I bought a 1970 Buick Electra for my new summer cruiser. This baby is damn near flawless... The wierd thing is that it has an Oldsmobile 403/th400 in it. Now, I suspect a buick motor was removed because it is a 1970 for one and they didn't put olds motors in 70's and the 403 was only made from 77 to 79 if I've researched correctly.
Now the guy said that it shifted like crap if it ever shifted out of first gear and he told me it had no kickdown.( I knew in the back of my head that was because the th400 has the electric thing that goes to the switch at the pedal). He also said the Power steering pulley was crooked and needed to be fixed before the alt. belt ( no a/c) would go on without getting slung apart. I found out the wire from the pedal to the transmission was unhooked so I fixed that, and then I got a new belt and straightened the p/s pulley out.(no bolt where the p/s brkt. meets the alt. brkt. was the problem).
So I went to start the car after repairing and noticed the pully for the p/s wasnt turning and this made the alt. just turn without turning the belt.
THEN I realized that the distributor's BAT and TACH spots werent plugged in and there was no wires in sight to plug into it.
I don't know where they went, but the car won't start now and I drove it home with no alt. belt already, so I know there was something there to make it start the first( and only) time I've driven it.
My question is...
1. I suspect that they used a buick wiring harness for an olds motor...is this possible?? the 403 looks to be bone stock.
2. Does anyone know of a wiring diagram so I can find an IGN wire to splice over to the battery terminal for the olds 403 HEI dizzy? there are 2 wires that are somewhat close to the dizzy. One is red and thicker and the other is green and they're on the same little connector. My guess would be it's the old harness that went to the coil for the old points dist. set up.
3. Kind of unrelated to my problem, Can I fit an edelbrock 4 barrel 1401 600cfm carb on the stock 403 intake?? I loved my eddy on my old chevy 350, just didnt know if I could switch out the old stock carb for the fresh eddy. I just wanna drive it down the indy streets and make the old fellahs slobber at the classic buick with the 22 year old in it haha
and NO I won't be putting 35" rims and 6 12 inch woofers in the back.... lol My daddy raised me with some dignity...
Thanks in advance for the help guess, you haven't steered me wrong yet!
My question is...
