Currently looking for a Air Compressor for my garage. I would like it to be powerful enough to run my 1/2 inch impact. I have been checking out Sears website but still cant decide what to buy. I would like to stay in the 300-500 range thanks.
Thanks for your input really appreciated. I just checked out the Husky unit but the only problem is my garage is not set up for 240. I should check into the cost of having a electrician setting it up for me. I think the husky unit will work great for me.G-Body_Vet said:I wouldn't buy anything less than a 60 gal for moderate garage duty. Don't get caught up in the HP advertising hype, look at what you need for CFM requirements to run your impact. Since I do a lot of media blasting, I need something that delivers a consistent 12CFM+ at 90psi and above. I also advise against anything with aluminum pumps, go for cast iron. Pay attention to the warranties too. I've seen everything from 90 days to 4 years.
I'm shopping for one again too after fragging a direct-drive, Craftsman oil-less pump for the 2nd time. Avoid those like the plague and get a belt driven compressor. The cheapest 60 gal I've seen is a 3 hp Husky from Home Depot for $449. To be honest, it's an entry level compressor for a 60 gal. Menards has a decent looking Sanborn in that range too. Just about any home improvement store or farm equipment/supply store will sell compressors and usually sell them cheaper than Sears.
I've read so many reviews and no matter what brand you go with they're all hit and miss. Everything from Belaire down to the Harbor Freight models can have problems. To be honest, the 3.7 hp 60 gal Harbor Freight unit has the highest CFM rating of the compressors in the same class.
You might check out some local commercial/industrial auctions too. The crappy economy is putting a lot of business on the skids. I've been to a few and gotten some great deals. I got my 6' tall Jet drill press for $40. A company I used to work for went through this and they sold a 6 month old $12,000 rotary screw compressor for $1500 and 2 15hp/200gal (probably $4000 new) sold for $200 each.85GPLef41 said:look on your local craigslist as well...
