need help with power seat
hopefully that is the problem
how hard is it to replace the power seat coupling
do I need to remove the seat
I have no idea where to start
Bweavy thanks for the fast reply and the link to the part I really appreciate it
If you can tape that coupling back together to get the seat to move so you can pull it out that is the easiest. If not you can loosen up the 3 7mm Screws on the motor & remove it. What ever you do be careful with the plastic transmission. The rebuilt units are expensive & used are tough to find in good shape.
how would you suggest that I get to the motor
would removing the seat be the best option
is there any tips on how to remove the seat
my seat is set to the rear of the track so I think it will be hard to get to the bolts in the back
If it is to the rear & the front is up it is easy. Easier if the seat is out though.
Here are a few tricks I have used over the years.
Dewalt battery With a junk yard lead spliced in. Great for moving tracks with no power. I call it the Weaver generator.
Crazy glue your coupling together for the move. Do not sit in the seat while doing this. It will not hold up. Duct tape or electrical tape will work in a jam on a coupling. Once again do not sit in the seat while moving.
Drill with a junk yard cable. Only if you can acess the cable to the track.
in your case do the back screw first. This is the hardest screw to get to.
Loosen the motor & install new power seat coupling.
re attach the back screw first.
If you can only access the front bolts loosen them up & remove. You can rock the seat back. Just don't snap the tracks.
:rofl: weaver generator!!!
I dont even see a power seat coupling but it looks like my power motor is coming apart
where can I get parts for this
see the little circle. there is a crack right there and inside the big circle a piece of the motor came off
help please
jamon 8 said:
I don't even see a power seat coupling but it looks like my power motor is coming apart
help please
Looks like a trip to the bone yard for another seat track. 😢
That's what I had to do for my old 88 Eldorado No new parts were available.
