I am new to olds engines. I am a chevy guy but i got this 1981 trans Am last fall that had a 403 in it. The car needed some tinkering and the previous owner didn't have much time to fix it. but I got it running, it has a 403 with under 1k on the rebuild, pumched .30 over, high performance cam, , mild porting on the heads and intake, had new rods and lifter installed, and the usualy new stuff, and I also have headers on it. I am runnning 650 holly.
Now I know this engine should be making some power, but when I step on it, there isn't much there, its like its only running on 2 barrels on the carb, accelerates slow. Then the engine tops off at around 4K rpm, then is will start to sputter, won't rev past that.
Any ideas? I know this engine stock has some torque because I have had a stock 403 trans am a few years ago and it could burn the tires off all day long. the car also bet a push rod, put new one in and it worked the same way
