need link or place to find rear window trim clips.???
avin85cutty
Feb 9, 2012
77
i bought a cutlass that was a vinyl top at one point but was removed. im getting ready for paint and need to know where i can find the clips needed to hold chrome rear window trim in place?? or is there some kind of glue that will do the job?? if u have any info please let me know asap.. im getting ready for paint in like 2 weeks. and i dont know if i can or want to do this after the paint job
I got all my stuff for my El Camino from these guys, http://www.clipsandfasteners.com
They have a great selection call em they probably can help you out. 8)
I got all my clips and headlight adjusters everything for my restoration.. Ask about reveal molding clips. Hope this helps.
I replaced most of my clips and was able to get them from the local dealership, I couldn't believe they were still able to get them I just found the box and the number is 3066259 they come in a box of 10 hopefully this will help
So big block,
Just so I get this right all u did is drill a small hole in the actual trim then use those screw to hold it in place?? Also what did u screw them into? The metal body of the car or between window edge and the body of the car? Cuz if that's the case is sounds alot easier the using the clip mounts.
avi n85 cutty said:
So big block,
I believe those screws hold the clips to the body,then you snap the reveal molding on the clips (The screw takes the place of the T-posts if yours are broken or missing)
when i pulled off the vinyl top, my car didnt have no studs for the chrome strip molding clips. i had to install these screw studs before i could install the clips. i have read, that some vinyl top cutlass came with these studs. you need to look and see if there are any clip studs in place. if not, you will need the screw studs to hold the clips, and then install the chrome strip.
