Hello All,
I'm new to this forum. I don't actually own a G Body (well, I have in the past... does that count?). I do own a 1952 Ford F1 pick-up that has a front frame spliced from a 78-82 G Body that was done by a previous owner.
They didn't provide enough positive caster when the splice was done, and I'm looking for ways to compensate short of cutting and reinstalling the sub-frame. I need another 5 deg of positive caster (I'm at -3, spec is +2).
I've found that Moog makes upper control arm bushings with eccentric holes that can add caster, but I can't find one that fits the G Body control arm.
I have also found one supplier that has tubular control arms that are adjustable, but they're rather expensive.
Have any of you ever had to add more positive caster, and if so how did you do it?
Thanks!
-DV
Thanks!
-DV
