need motivation
Blurrss
11
Kind of down and need some motivation to get back to work on the car. Knowing all it needs is a shifter and cable and an oil pan gasket. I really don't want to pull this motor but being in ND without a heated garage I need to get moving.
I put the motor and trans and drive shaft in, got the thing started. then found out it had a massive oil leak from the oil pan. Of course this is after I put the front cap back on.
Here's some motivation: go out and work on your car. It's not going to get done if you don't go out and do it, and working on a project is the best way to get into a project, so go start doing something even if you don't feel like it. Before you know it, you're going to be totally into it and you won't want to stop. I speak from experience.
