My engine was running smooth as butter. But i had to replace the valve cover gaskets. After doing that, I degreased the engine. I removed everything from the intake manifold, and took the rest of the emissions equipment off too, so I could get to the actual engine to clean it.
After I finished cleaning, I put everything back together. While I was at it, I changed the plugs, fuel filter, PCV valve, breather filter, fixed all the damaged wiring, ran all the wiring thru new convoluted tubing, and finished replacing the rest of the vacuum lines....also replaced the "ported vacuum switch", that I broke earlier.
And then I changed the oil, just incase some of the cleaner or water managed to make its way inside.
Well, now when I crank it up, it runs ROUGH. It's having trouble idling, and sounds like garbage. Sounds like its got an exhaust leak, and misfiring. I moved it around in my driveway, and there is almost no power at all. This was a few minutes ago, after dark, so I really can't jump right into it and pull everything apart again to figure this out. Gotta wait till the morning.
So any ideas what I might have messed up? I'm gonna re-check all the connections, make sure the plug wires are on right. Then I'll try to rig up a smoke machine to test for vacuum leaks....Or I'll just do the cigar trick.
Is it possible for water to get up in the distributor? I'll pull the cap off and inspect it, but I've never messed with a distr. before, so I wouldn't know what to exactly look for, besides corrosion.
Excuse all the stupid questions, but my mind is racing at the moment. I was planning on taking my car down the road and renting a bay with a lift, in the morning, to install my new lowering springs, and transmission filter & pan gasket. I wasn't expecting to be dealing with tracing down engine problems 🙁
