Need tire help
elliottw
May 26, 2009
72
8
north dakota
Ok I don't know very much about tires or rims at all so i need some help selecting new tires cuz my back tires are shot. The tires on there now are 235/60-14s and I was wondering whats the biggest, as in tall and wide I could fit on the rims. Any help is appreciated.
goto tirerack.com and see what they have. search by year make and model or just tire size.
well if ya want bigger tires, yer gonna need bigger rims. 15x 8 rims are pritty much what i would like all around except have a shorter sidewall in front.
205/70/14s 25.4" tall in front with 245/60/14s 25.6" in the rear make for a great combination. Its max width for the rear. You can get up to 225/70/14s in the rear but most of these cars are geared too tall already.
Edit stock height was 25.5" or 26.0 for the performance modles ie GN/Ttype/442/MCSS
Just remember, making your tires taller or shorter will throw off your speedo. Plus make a difference in your launch and top speed.
On my first car, I put the tallest and widest tires I could fit on the back. I even had to put in air shocks to lift the rear up a bit so they would fit. Then a buddy gave me a set of old tires to use as burn out tires. They were 2-3 inches lower than what I had on there. And the first thing I noticed was that my car launched a hell of a lot harder that with the tall tires.
So consider your gears when you decide on how tall of a tire to go with.
See someone who owned the car before me put some springs or a bodylift in it or something, because it sits all hotroddy. Like the rear is sittin kinda jacked up. I don't mind the stance but it makes my rear tires look super small..
