Im needing help on how i should set my fuel system up. This is what i got so far, 100 micron filter to a A100, -10 feed line to a fuel log with my Carb reg and my Nitrous reg, then out the log with a -8 return. Question is do i need another reg before the log to drop pressure down or put it after the log on the return side. I havent bought another regulator yet Areomotive says to run there bypass A1000 regulator. Is there anyone else out there running this pump, with a simular type set up.
Thanks
Thanks
