Good Day!
I recently acquired a 79 malibu. This malibu has a 350 V8 in it with an automatic trans. The car already has a full cage in it as well.
The car was set-up for drag racing for the last 10 years. It doesn't seem like anything was done with the suspension other than maybe some aftermarket springs.
I am running a few road races this year and want to run this car. I normally run my 87 Mazda RX7 turbo, but thought I would give a domestic a try!
I figure, I need to do something about the HORRIBLE front suspension geometry! I figure the easiest way is for longer upper AND lower ball joints. Anybody know where I can get ones that will go in the stock control arms?
Next, I will get the front anti-roll bar off an F-body iroc Z.
I was thinking about using an aftermarket rack and pinion set-up to eliminate the bump steer and wandering. I know you can get a quicker and better feeling box off of an Iroc Z also, but then I still have to deal with the bump steer. I can get an aftermarket rack and pinion for about $200.00.
I am planning to get a poly bushing kit for the entire car as well as some stock replacement springs that are stiffer (somebody posted a good link on another thread... ...I will have to search again!) Finally, i found some bilstein shocks for these cars for only like $60.00 apiece!
I am also going to tie the cage in to more places and brace the front and rear ends ALOT more than stock.
Am I missing anything?
Thanks!
Rob
Thanks!
Rob
