New Fish
RedEyeLuvBuzz
6
6
51
Hey folks, noobie here with a1988 cutlass supreme. It was found half buried in a field. I've replaced the gas and brake lines along with the brakes. One rim was mismatched so I swapped them for some old schools then put on air shocks and extra large springs to lighten the load. The steering wheel was a rust ring so changed that out along with the ignition switch for there was no key. Finally, new belts, oil change and tune up made it drivable. I'm not sure where I'll be going from there but I'm hoping for ideas and inspiration from you all.
Welcome! You've already made some nice improvements. If rust free that car has some potential. Sweet headliner
Thanks
There is surface rust on the hood and the frame but a good cleanup and some paint will make it last long enough for me to have some fun and learn a bit more.
Reactions: L92 OLDS
Qho did the headliner?
Were are you from? That looks like a old Iowa plate on the Monte. Welcome from Jewell Iowa.
Welcome from NE GA , looks like you have good start , and a solid platform .
