new member
matthew_rhodes
Sep 4, 2010
78
mobile, al
So I'm 17, the names Matt, and I have an 84 Cutlass Supreme Brougham. I'm making the car a race car so I'll probably have some parts up for sale later today. Looking forward to the knowledge I'll hopefully gain from this site.
Welcome to The Site, Would Love To Hear Your Plans In Detail! Good Luck With It, I Bought My El Camino When I Was 17 in 2007 and Am Currently Building A SBC 355 CI, and Swapping The TH350 Out For A Four Speed Saginaw!
well I'm starting it in a beginner league so I can't do that much. Pretty much a roll cage, fabbed dash, quick release steering wheel and straight shaft to replace the column, rebuild the sbc 305 that's in it, and add a plastic nose piece. Possibly rebuild the transmission as well but I haven't thought too much about it yet. Also, I have to do some minor patchwork on it where I took of the vinyl top. Later on I hopefully can afford a 8.5" rear to stick in there, but I'll have to stick with the 7.5" that's in there now.
Tuggy24g said:
Welcome to the site! Well just make sure you do not make the 305 to powerful for your 7.5! They can only handle about 350HP unless the rear was taken care of.
that 305 has to be pretty much stock so I doubt I'll do any damage...
" A Engines and all components must be for make, model and year of car and meet specifications below. GM cars may substitute stock 350 engines in place of 305 but must within same year range. Oil pan must have 1" inspection plug in line with crankshaft casting number.
B. Maximum allowable compression 165 pounds
C. Melling CCS-2 is the only cam legal for gm cars.
Mimumum 20 inches of vacuum at 1000 rpms or subject to tear down.
D. Transmission and rear end must be for make, model and year of car.
E. May remove all A/C components."
welcome,is it legal to stroke the 305,because enginekits.com has a 335 stroker kit for the 305.and good luck with it.
nah, you cant do anything really. I'll eventually get a 350 later on; I just figured I'd use what it came with first.
welcome if i can be of any asst.please let me know iv been dirt trackin for lots of years and all i run are cutlass and g bodys
