New User
WRMDOVR
n00b
Sep 9, 2022
62
Hello all.....new to this forum as I just bought s completely rebuilt 1986 231 with turbo 350 trans. Bored .30 over with Aluminum intake, RV type cam, etc. This will be installed in highly modified 1958 Morgan with custom boxed ladder chassis, ford 8.8 narrowed rearend with LSD and 4:11 gears...drilled to accept 5x5.5 bolt pattern. 4 inch dropped I-beam front axle with disc's all around. Running Vintique true spoke wire wheels with 5 x 5.5 bolt pattern. Modified body....moved rear bulkhead back 4 inches and moved firewall forward 6 all in the name of ergonomics. removed wipers and windshield...using 7 inch high windscreen. Once completed the target weight is 2000lbs. That kinda paints the picture of where i am going......1950's/60's road-racer vibe.
I am looking for a set of headers that does NOT hug the block.....I need the headers, preferably center dump..... to exit the block and extend by 2-3 inches outward horizontally as my frame rails are directly underneath. I have done ALLOT of searching on the web and have found nothing. I trust that this makes good sense and if anyone can point me in the right direction that would be awesome! Thanks.
