Hey all, names Josh from VA own a 86 elcamino got it from my grandpa for christmas bout 5-6 years ago. When i got it it was completly stock but i cant leave well enough alone. So during high school i put a big cam in the 305 and shortly thereafter it wiped, i pulled the motor and gave it to a freind after buyin a 350 after i graduated. I got it off Craigslist put a edelbrock intake on it Proform distributor it already had comp cams roller rockers and a small cam dont know the specs.
put it in with a 2400 stall converter in the 2004r trans and soon after it bit the dust. Saved my pennies and then replaced it with the current trans, a t-350 with strong sprag and shift kit and 25-2800 stall and Jegs crossmember. now im in the process of figuring out the cheapest way to put a ford nine inch in it whether it be cut and fit the one ive got of buy a housing premade for the car. Ive run it at the local dragstrip 9.6 @ 75mph 1/8th mile not too bad for having stock rear no posi and 2.73 gears and that was with slicks, normal tires ended up just spining halfway down the track. Thanks and i look forward to pickin yalls brains.
