I just acquired a very solid and decent shape '87 442. It has a '69 Olds 350, but the heads are the smog '74 heads. 200R4, 3.73 Posi 8.5"
First order of mods is a Fitech EFI throttle body system, fuel tank, sending unit and in tank pump assembly all coming from Summit Racing this week. I'm not a fan of carburetors.
I looked into doing a Olds 350 build that was done by Powerblock TV. Keeping in mind I wanted to keep it as stock looking as possible. But after doing some checking for air cleaner clearances under the hood, there is no way the Edelbrock Performer RPM 7111 manifold will work. It's 2" higher than the stock manifold. This is the only manifold that will work with Edelbrock 6051cylinder heads. So is there a stock GM air filter housing out there that has a drop base that could gain me about a inch of hood clearance? Or would I have to resort to a open element air filter?
Are there certain Olds heads that flow real well that I could search for instead of the Edelbrock heads?
This is the link to the Old 350 build for anyone interested. There are some ads in there so be patient.
http://www.powerblocktv.com/episode/HP2012-13/an-old-olds-repurposed-for-new-power#.Vx1uImOGooU
Or my other question is should I scrap the Olds 350 build and just build a Olds 455?
Are there hood clearance issues with a 455 engine swap?
I appreciate any help.
