Now this is ROCKET power!
FE3X CLONE
2,714
53
48
Ohio
crazy. think about how much $$ goes into the drivetrain paired to that beast
Or the suspension, frame, and entire rest of the car to even remotly be able to hold things together. :shock:
psh who needs suspension and bracing 😀
Man that thing must of costs hundreds! :wink:
you could probably put a small space shuttle in orbit with that thing powering it, then it'd really be rocket powered. :shock:
Build specs from Realoldspower.com:
4.100 bore x 3.48 stroke
DX block with 4 bolt caps 1-4 and 4140 billet rear cap, bronze lifter bushings
JE custom blower pistons
Crower billet rods
Crower billet crank
Comp Cams custom roller .710/.714 lift 269/276 @.050 on 112° lobe sep.
Edelbrock heads 2.100 int 1.65 ex
Crower rockers
Jomar Stud Girdle
Victor intake
Ultimate Speed and Machine 850 annular Ethanol blow thru carb
E-98 fuel
Non-intercooled F2 Procharger @ 56K
32 psi Boost
IAT's 120° below carb @ 32 psi
9.7:1 comp
34° timing
Custom Headers 2-1/8"
I think that build is reserved for thrill seekers. You've surpassed the point of enjoyment and have chosen to defy death if installed in a car :lol:
Yeah, and like someone mentioned on ROP, just think what it would do if he installed an intercooler.
Seriously though, 32psi of boost? That has to be fun. 🙂
