Can't get it from GM anymore. 3rd party you can, like ebay.
Guessing 307 Olds V8 or Chevy 305?
New is $150.00 + 8.00 shipping, plus any sales taxes.
1985-1989 Chevrolet Blazer. 1985-1989 Chevrolet Suburban. 1985-1989 GMC Suburban. 1985-1986 GMC C1500. 1985-1986 GMC C2500. 1989 Chevrolet R2500. 1985-1986 GMC C3500. 1985-1988 GMC G1500.
www.ebay.com
You're talking about the Computer connector 4 pin that goes to the passenger side, correct? Olds 307 and Chevy 305 uses GM p/n 1979733.
Do you need one? Ima gonna guess so. It helps to know what engine you have, though. They have different ones depending on your setup. It appears the only difference in the new ones is the color of the retainer block and the wire colors. They still go to the same places.
It JUST SO HAPPENS I have a good, but used 1979733. Today I was putting together a Delco distributor with all new Delco parts (except for shaft and gear). The distributor I took the shaft from still had its electronics.
The end of the security clip which holds it to the module broke, but the darn thing is so tough to put on and pull off, you wouldn't need it anyway.
It actually mounts inside the distributor with a little screw and the wiring is hanging out the side of the distributor.
Part is delineated with the red arrow below. The yellow arrow is pointing to the little piece of security clip that is broken off the used part. It won't affect the operation at all.
If you think you can use it, I'll send it to you for the cost of shipping.
Make sure it's the part you need, though. If it's a 6 cylinder, it could be different, I don't know.
