Hello All
More info needed as usual!!! Being picky and want everything on this car to work. Latest 2 small issues. Trip odometer does not work nor be able to set to zero. Seems froze up
Next want to set the clock. Clock is working but when you pull the stem out to reset the entire thing comes out. You have a 3" long stem (cable) in you hand. Probably need to pull the instrument cluster but then what??
Thanks to all in advance for the help
