Is it possible to get factory or replacement side post battery cables? My cables are all doctored up and I think that is to blame for my volts light every morning. Thanks
87REGALPRO said:Is it possible to get factory or replacement side post battery cables? My cables are all doctored up and I think that is to blame for my volts light every morning. Thanks
Same here. Well if it helps rockauto.com still has the negative ac delco cable but the positive one was discontinued. :x I just had a thought. I did see a set of cables on a cutlass yesterday but given the age of the car and condition of the engine I would not what the cables. How ever I was thinking maybe look for a good set of side post connectors and just cut them off and try to solder to the ends of your current cables ( with the ends cut off of course). Just an idea. Right now some one poorly crimped top post connectors and they are loose and copper is exposed. Also just today I was doing electrical work and found out that I can just twist the connector free. :shock: Thats bad. Anyway if you find out anything else please let me know.dan2286 said:87REGALPRO said:Is it possible to get factory or replacement side post battery cables? My cables are all doctored up and I think that is to blame for my volts light every morning. Thanks
I need to know also. I don't want those universal ones they sell at parts stores.
I need the positive for the stock buick v6. What is the difference between the battery cable for the v8 and v6? Thicker? Thinner? If the cable is to big will it destroy the electrical system or damage the engine? ThanksBonnewagon said:RockAuto still has the AC Delco pos and neg cables. Here's for a Regal with 307.http://www.rockauto.com/catalog/x,carcode,1020980,parttype,2500
Yeah I'm not a fan of cheap crap. Plus from the inside people I used to know that worked at these "Chain stores" sell inferior products mostly for profit. Btw since were on the same subject where does the other ends of the cables connect to? I see the positive cable running past the front behind the pulleys but can't see its ends. ThanksBonnewagon said:I'm not sure if there is a difference at all, besides length. GM actually used the thickest possible cable gauges for all it's cars. It's the discount store brands you need to worry about. They are famous for showing a thick cable that's mostly cheap plastic insulation with a tiny copper wire inside, same thing with jumper cables.
